train22 said:....ok, looks great, what are we suppose to answer? got any particular questions? Yes, you should put at least 1 side fan, 1 top exhust, and I would suggest a front intake.
train22 said:I would suggest a hole saw, it's simplest and most proffesional. will give ya great results with ease.
Like I said in the last EDIT, cut that grill off, it's just as bad as having no fan in there. You always want to have as much air as possible and grills like that is bad, A ducts is really the best solution.
