Ebola said:buy a new chip. hehe. the 466 doesnt go too high. chance are you can hit 525 with the stock heatsink. this is 75 fsb. at 83 fsb your gonna have data corruption problems so its not worth it. this chip wont hit 100 fsb unless you ln2 the thing which is stupid.
either go with 525 with 75 fsb or buy a new chip. the katami core that the 466 uses is limited to arround 600mhz anyways.
Sir-Epix said:
The Celeron's don't use the Katami core. That is just the 512kb PIII's. Celeron's use the Mendicino core. Add why even bother getting a good heatsink/fan for the celeron...it is not going to overheat with a standard heatsink/fan. Trust me! I tried to kill this little Celeron plenty of times...it just won't die!
Zuck Gou :) said:Your board is a BX chip I think so if you want a chip to really overclock and have some fun with try finding a Celeron 600/633.
If you want a faster chip then go buy a Cel 900/1ghz, but overclocking wont yeild the higher percents.
Elmo said:oh, and i cant put anything better in my Chaintech 6BTM motherboard - it supports only up to PII 450 so im gonna have to change it anyway
