I bought a used, but "working" XFX 6850. I didnt test it.
1- i removed the stock cooler, and try to add a aftermarket cooler, but it had four pin conector, so i just connect it to the card 2 pin connector only 12v and ground. (i check manual and i think i didnt mes the cables)
Turn on, but it didnt spin
2- ok ok, didnt work so i put back the original cooler turn on, but even the origina lone dont spin O_O
extra:
- i didnt try the card with the original cooler before removing it
- yes i connect the stock cooler pin
- also no signal to the PC and almost sure pc dont boot
- no burning smell, no burned part, all look good
Ideas?
extra:
Ideas?
