For those interested in 4K monitors, my problems may be of interest to you!
I have sent the following email to nVidia cs as follows:
How to cold/warm boot to my main display connected to Display Port?
Motherboard : Gigabyte GA-Z77-D3H v1.0 with F22 uefi bios
I have recently acquired a Asus PB287Q 4k monitor and connected to the Display Port as my main display. Another 40" LG LCD panel connected to HDMI as extended display for movies.
1. Cold/warm boot PC, Bios boot screens will only appears on the my HDMI extended display. It will be nice to have them on both displays. (w7 boots OK into the main screen.)
2. Warm boot to w7 will always black out the main display connected to Display Port, while the HDMI extended display is OK.
nVidia replied as follows:
Hello Stuart,
Thank you for contacting NVIDIA Customer Care.
This is Vaseem assisting you with the query that you have.
From the email, I understand that you would like to know how you can get both the screen or at least the Display port screen to show the Booting screen.
I will be glad to help you on the query that you have.
Please be informed that the Dual display or multi display feature will be activated only once you are in the Windows and once the boot process is completed.
With regards to HDMI taking the primary display, the ports on the card will have a certain number as to which one will be the primary and then the secondary.
In your case, in comparison to the Display port and the HDMI, the HDMI seems to be the primary one and hence the Boot screen or Bios screen shows up on the HDMI.
This is a hardware design of the graphics card and hence its completely normal. There is no way we can modify this unfortunately.
Please feel free to let me know if you have any questions.
Regards,
Vaseem
Unfortunately, the warm boot black out at my 4K monitor connected to the Display Port was not addressed.
Does anyone have experiences with difficulties with Display Port connection on nVidia or AMD graphic cards? Anyone knows fixes to my problems?
For those who opt for 4K monitors, I suggest you guys should wait until such problems are ironed out.
stukan.
It seems to me having display on all three available display ports (Display Port, HDMI and DVI) can be fixed by a driver revision and nVidia should be able to do it with ease. Why nVidia shy away with it is beyond my comprehension.
However, warm boot black out on the main screen connected to the Display Port is a definite problem nVidia should address. No one can work with the extended display alone on w7.
I am still awaiting answer from nVidia on my second question.
I wonder if AMD graphic has the same problems with Display Port in a multi-monitors setup!
Hello Stuart,
Regards,
Vaseem
stukan.
