- Sep 22, 2014
Have built two or three water-cooling systems for some friends and myself included. My current one is not old but i felt I wanted to get a build log going for my new one.Going to let the pictures speak for themselves. Parts list will come as I go.
NEW UPDATE:
Switched most of the build to and EK heavy build because only waterblock for my GPU was the EK Classy 780. Keeping the XSPC radiators because they are beautiful and not getting the frozen Q res anymore. Not needed with the mayhem fluid and clear hard lines.
(Orange= ordering or already have)
System: (Already have all SYSTEM components in other computer)
Processor: AMD FX-8350 4.0 GHz
Motherboard: Gigabyte GA-990FXA-UD3
RAM: G.Skill Sniper Series 16GB(4x4GB) 1866
GPU: EVGA GeForce GTX 780 3GB 384-Bit Classified w/ EVGA ACX Cooler
PSU: FirePower ModXStream Pro 700W 80Plus Semi-Modular
Hard-Drive: x2 1TB VelociRaptor 10,000 rpm 3.5 Hard-Drives
Cooling to Come:
EK Supremacy EVO Universal CPU Liquid Cooling Block - Acetal + Nickel CSQ
XSPC RX240 Dual 120mm Radiator V3- Bottom
XSPC RX480 Quad 120mm Radiator V3- Top
EK EVGA 780 Classified (and 780 Ti Classified) VGA Liquid Cooling Block - Nickel + Acetal
Swiftech MCP655 Variable Speed 12v Water Pump
PrimoChill 1/2in Rigid PETG Tubing - 36in - Clear
PrimoChilll 1/2" OD Rigid Revolver Compression Diamond Knurled Fittings- Anodized Black all the way around
EK-MultiOption RES X3 250 - Liquid Cooling Reservoir
Mayhems Pastel Coolant Premix - 1L - Red x3
EK Monarch Series X4 Ram Liquid Cooling Block - Acetal + Nickel CSQ (EK-RAM Monarch X4 - Acetal+Nickel CSQ)
EK RAM Monarch DIMM Module - 2 Pack - Black (EK-RAM Monarch Module - Black (2pcs)) x2
maybe some led lighting.
Build is going to be over a few months.
Thanks for those that tune in.
Case is a Phanteks Enthoo Primo Ultimate Liquid Cooling Full Tower. In the pics I have the accent mesh pulled of to be painted.
NEW UPDATE:
Cooling to Come:
