What is up O.C.F
The kit in question i have is
Corsair Vengeance 4 x 4 GB (althought im only using 3 out of 4 dimms in tri channel)
Part #: cmz16gx3m4a1600c9
I can get it running at 1528MhZ (191 * 8) fine and recognising all 12GB, using the standard voltage and timing.
But as soon as i try to but the Ram multi to 10x windows does the old "12GB (8GB Usable) trick, and not mixture of timing (tried 10-10-10-31-2), voltages (1.54 - 1.66v) seems to work.
Im purely wanting to achieve the 1910MHZ Ram OC for rendering purposes and benchamarking, so any help would be appreciated.
EDIT: i got all 12GB to recognise with 11-11-11-31-2 timings so im just wondering where i should start with improvements?
I used to have OCZ Reaper DDR3 but they were 2GB dimms so i pulled them out.
MY CPU OVERCLOCK is as follows:
I7 920 do @ 4.01ghz ~ 1.275v
QPI/VTT: 1.36v
Uncore: 191 * 20 = 3820
RAM: Corsair Vengeance 12GB @ 1528mhz currently at 9-9-9-24-2 ~ 1.54v
MOBO: GAEX58-UD5
QPI/VTT: 1.36v
MOBO: GAEX58-UD5
