Hey all,
I posted this in another section but no response so I thought I would post it here...
This is my current setup: 4690k at 45 * 100 = 4500 MHZ @ 1.18 VCore.
Prime95 26.6 small FFT's (30 mins) temps top out around 70
Intel Burn Test (30 mins) temps top out around 80
AIDA64 (30 mins) temps top out around 68
Keep in mind I have the fan profile set to "silent" (one of my requirements - I don't want to hear this thing ever). If I set it to manual full blast these readings are a couple of degrees lower.
But then there's Prime95 28.5 small FFT's... Where the temps jump to 85+ in a matter of seconds. I know this is due to some sort of AVX thing, blah blah blah, and it seems the general consensus is that this is not a valid benchmark. My question is: Will my CPU ever see this under normal circumstances? The computer is used for light gaming, internet, downloading, office work, etc. Should I just ignore this 1 extreme and base everything on the other stress tests I've done? I have RealTemp set to run minimized on startup, and I've never seen anything over 65 while gaming or doing anything else.
Thanks!
Thanks!
