Hey guys, could you please tell me which is a better $2,000 gaming build? (To be used with a 34” UltraWide Cured Monitor) (3440x1440)
These are options i found on the web:
1. http://techbuyersguru.com/2000build.php
2. http://choosemypc.net/build/?budget=2000&oc=true&options=od [Set to $2000, Overclock: yes, +Optical Drive]
3.
I could sway away from these options if needed. This PC would also be intensively used for Music Production [FL Studio] which requires a really good CPU + RAM
1.
CPU: Intel Core i7-4790K
CPU COOLER: Noctua NH-U14S
MOTHERBOARD: Gigabyte GA-Z97X-UD5H Black RAM: Patriot 2x8GB DDR3-2133
SSD: Crucial MX200 500GB
HARD DRIVE: Toshiba 4TB 7200RPM
GRAPHICS CARD: MSI GeForce GTX 980 Gaming 4GB
CASE: Corsair Carbide Air 540 Black
POWER SUPPLY: EVGA Supernova G2 850W
OPTICAL DRIVE: Samsung 24x DVD Burner
or
2.
CPU: Intel Core i7-5820K 3.3GHz 6-Core CPU
COOLER: Phanteks PH-TC12DX 68.5 CFM
MOTHERBOARD: ASRock X99 Extreme3 ATX LGA2011-3
RAM: Crucial Ballistix Sport 8GB (2 x 4GB) DDR4-2400 Memory
SSD: Crucial BX100 250GB 2.5" Solid State Drive
HARD DRIVE: Seagate Barracuda 1TB 3.5" 7200RPM
GRAPHICS CARD: Gigabyte GeForce GTX 980 4GB WINDFORCE 3X [x2]
CASE: NZXT Source 530 ATX Full Tower
POWER SUPPLY: Antec HCG M 750W 80+ Bronze Certified Semi-Modular ATX
OPTICAL DRIVE: LG GH24NSC0B DVD/CD Writer
or
3.
CPU: Intel Core I7 4790k
CPU COOLER: Corsair Hydro h80i
MOTHERBOARD: ASUS MAXIMUS VII HERO LGA 1150 Intel Z97
SSD: Mushkin Enhanced Chronos 240gb
HARD DRIVE: 1tb Seagate Barracuda 7200rpm
GRAPHICS CARD: Evga Gtx 980 Superclocked
CASE: Corsair Carbide 500r Gaming Case
POWER SUPPLY: CORSAIR HX Series HX850
Thank you in advance !
3.
1.
or
2.
or
3.
