Hi folks, I have a Corsair Vengeance Pro kit that I plan to remove the heatsinks (please don't ask why I would want to do that ). Case is, they are at stock speed of 1600Mhz and is highly possible that will be used at least 1866Mhz. I'm wondering if running at such speed without the heat spreader would cause any sort of damage to it? have anyone ran their RAM kit without the heatsink and with no issues?
I already asked this on another community, I got some good advises about avoiding doing it the best possible, but I'm still pretty sure I have seen it before while googling that using them without heat spreader wound't cause any harm or something like that, I'm almost decided to do it but I would like to ask you whats the worst that could happen when running without them, or if it actually does cause any harm to the sticks.
These are exactly my kit, except that mine are 2x4GB (8GB), not 16GB.
http://www.corsair.com/en/vengeance...dram-1600mhz-c9-memory-kit-cmy16gx3m2a1600c9r
Thanks you!
Thanks you!
