Looking for any info on what 144hz 27 inch screens have the most flexibility in customization, either one that can be reversed 180 or one that extends forward from the base by a good 5-10 inches? Further more if there any known brands to have the best swing arms or wall mounts?
http://forums.blurbusters.com/viewtopic.php?f=2&t=2413 Original thread with no replies yet
Basically i want to be able to use the room under my screen for a extended mouse pad without being forced to move the monitor back. The White is the space i currently use, the Red is the space i want to use and the Blue is the space i would probably use with a extended mouse pad / 60% keyboard. Where the mouse is in that photo is where i have the absolute best aim possible. I play at 58cm/360 (23ish inches) degrees so its kind of low sense but its annoying to have to go down when i want to turn, or lift and swipe rather then just swiping.
This product is local but 35cm (14ish inches) is about 5-10cm (2-4 inches) too short for my desk or a bigger one which i hope to purchase, FPS gaming is very specific on setup and i would rather not change screen distance unless a 27 inch would give same affect further back, but with my local stores and or return policy i probably cant just test everything for myself.
http://prodimex.ch/pInfos.aspx?CODE...de+montage+pour+1+ecran++ORAEQ+MA011EU+GBA01+
