- Dec 4, 2008
I've seen this old junk rotting away in my Mother's inlaw backyard for a couple years now. It would make a nice benching platform....but that would take too much elbow grease just for sanding and refinish.
Well, I took it home and been working on it little by day by day for the past two weeks just to grind and sand it down.
At first I was just going to finisht the top only...but kept going and finished inside out. Did not plan to make a working progress until after the first coat of paint. It looks great.
So....here it is.
Materials...
Freshly painted... (still have that old pair of rail rotted)
Underside
I found only one single side 14" Accuride heavy-duty ball bearing mechanism in the tool box.
(15" required...but 14" would do...no need spend extra money)
Mechanism in actions with 2 HDDs installed for easy wiring access and quick change.
It has room for 2 benches.........or even 3 if I really wanted.
DVD installed
PSU installed
Temporary it's done for now...as I just ordered some brass standoffs.
Some more cutting and drilling need to be done.
.......to be continued
So....here it is.
Materials...
Underside
DVD installed
PSU installed
