- Jul 29, 2004
- California
Hey, is it possible to use MULTIPLE CSS styles on a single HTML table, because usually you can only just have one style.
What I'm trying to do is create a template that will self expand according to the content that I will be feeding it via PHP, and the borders around the template require pictures because I'm doing it all fansy-like, and having a drop shadow around it. I'm using CSS styles to apply these images because of its repeatable function that allows the images to be repeated as the table expands bigger than the actual image.
The reason why I'm asking this is because I dont want to create 4 tables within themselves and have each one a style applied to them (one for each side). I hope you can get what I'm saying.
