I don't do a lot of wireless, but I want something that is going to last a long time and have plenty of port options and other stuff like that.
I have always been with D-Link (DIR-655) and its been fine...anything else noteworthy?
Stay under $100.
This is exactly what I was going to suggest. Couple it with a switch and you can have as many ports as you want.Stay under $100, what about "free"?
You probably have some old hardware lying around your house. Have you considered using, IMHO the world's best gateway software, pfSense?
http://routerboard.com/
They are awesome!
Considered routerboard, but after going through my parts box, I'd need a new motherboard which combined with the extra energy, space and noise use from a physical computer makes no sense.
Decided to go with the Asus N56u for $106 @ newegg. All the reviews seem to be about the best of most boards in that price range.
