Thought this would interest you guys since I know some of you are designing your own blocks for the GT.
Taken from O-C-3-D news article:
Author: Matthew Fogg
Published: 11/09/2007
Aqua-Computer Release the Aquagrafx G92 for 8800GT
German based water-cooling hardware manufacturer Aqua-Computer have released a full-cover water block for the NVIDIA 8800GT (G92). Not surprisingly the water block is called the Aquagrafx G92 and weighs in at only 480 grams.
* Copper base and high-grade steel top;
* Copper base and plexiglass top.
The plexiglass top will have G1/4 threads so that the connections can also be fitted above the block.
The Aquagrafx G92 is available for pre-order now for 79.90 euros ($116 USD), but shipping will not start until approximately 10 days time.
The images included below are of a prototype. Production blocks will feature a better quality finish and engraving on the top of the block.
The Aquagrafx G92 will be available in two styles:Despite the low height of about 6 mm the cooler with its 17 mm of broad channels reaches a good flow which is not narrowed by the G1/4 connections either. An effortful cooling structure which guarantees an optimal heat removal is over the GPU.
The graphics processor, the RAM as well as the 10 voltage regulators are cooled, in which furthermore another three voltage regulators which are not fitted on the current card are also cooled.
