- Sep 17, 2010
So I'm using a GB P55 UD-3R, and for overclocking I'm using Gigabyte's Smart 6 (Smart Quickboost) set to Turbo (3.0 ghz / BLCK 150 mhhz) with stock Intel cooling.
With Prime95 up overnight at 100% load on all cores, it maxed out at 87-88 degrees.
Safe to run it like this? Would you say that's a stable O/C considering the temps are a bit toasty?
Thanks!
Thanks!
