- Jun 24, 2001
- in the garage
I was about to attempt this on my CAK38, but wanted to know if it would end up doing more harm than good. The bottom of my CAK is ugly. See below. Is it possible to smooth it down with a 120 Grit sanding band? Or do I need to go get some regular sandpaper and do it manually? And what's this wet/dry thing people talk about?? Sanding it while it's wet??? Thx for the info.
