- Feb 27, 2002
- NYC, Brooklyn
Here's a little quorondrum, problem that I have run into, and maybe have a solution.
Problem:
You have done a fridge mod, and everything is working nicely, but you have the thermostat turned all the way up, which will either run the compressor full time (which will burn it up eventually) or you can not get to your coldest that you can with the fridge mod. How can you get your compressor to turn on and off on a fairly regular basis? A timer right? wrong, you want to cycle your fridge on and off every 10-30 minutes, depending on reservoir volume to keep it at the lowest temperature possible. The cheap timers that you get at home hardware stores cost 10-20$ depending on how many cycles you get per day (10$ for the 7 cycle a day, and 20-30$ for the 24 cycles a day). That means you could only cycle on and off the timer once an hour. The timers that would be perfect, that are adjustable for on and off times from 30seconds to 30 minutes are like 100+ dollars...
Answer (maybe, this is a tough logic problem, maybe the experts could help):
Is there a way to put two or more of the hour on/hour off timers in paralell or series, so that the fridge would cycle on for like 30 minutes, and off for 30 minutes? or able to get a smaller time interval between cycles by buying the cheap timers? hook them in paralell?
For example, you have timer one turn on and off every hour:
time:_____5---5:30-6---6:30--7----7:30--8
timer1:___off--------on---------off--------- on
timer2____-----off--------on----------off
combined__off-------------on---off----------------on
I realize that this would make time be off for 1:30 minutes, and on for only 30 minutes. This is kinda like an and statement, if you plugged one timer into another... only when both are on do they work... anyone interested in helping? If this was possible, it would solve alot of problems, since it's very expensive to buy the short cycle timers. Thanks, Bill
Problem:
