home made ghetto is the way to go! i have my volcano 9 at max speed, 4800 rpm, and i have both sides of my case off. I have tried alot of things, a carboard side with a duct, a Holms air heater blowing into my case, of course wiht fan only mode, ive tried a boxfan just blowing straight in. But the last thing i tried was i took a black trash bag, and modded it so it would be the perfect duct, i took the orange smart fan 2 off my volcano 9, and i ducted a the boxfan right to my heatsink, well lets just say it worked OK. Since the box fan had to fight to get air from 3ft down to 3 in, alot of backflow occured and not that much air was actually rammed through the heatsink. The box fan did not have enough static pressure. I wouldve stacked a second boxfan right behind it to increase static pressure, but i most likely wouldnt have had any luck, there still wouldve been backflow and not only would i have to worry about 1 fan motor overheating, but 2. Yes, the box fan was under so much load within 5 mins i could smell the motor burning. Maybe it wouldnt be under as much load if i had 3 box fans, but i thought ahh ill just screw that and try somthing different until i get water cooling. So i put the smt fan 2 back on, at full speed, and then with both sides of the case off, back by where the hsf is and the psu, and the other open side of the case, hot air was building up there, so i glued 2 80mm fans between the top of the case and the mobo tray. So now i have everything open, but in the corner where the cpu/nbridge/psu is, has got everything exhausting. So all the air gets pulled up there and most goes into the high powered orange fan, and then through the heatsink, and then after that all the heat gets sucked out the back by either the psu or the 2 glued fans. also i have the IO panel off so its kinda open and allows the hot HSF air to blow out that way too. This has kinda worked the best for the amount of noise it created, i could get 2 degree better temps, but id have to put up with 80 deicbles of boxfans.
