- Feb 25, 2013
- Spring Hill, Florida
The first 99% of my Sapphire 7970 is straight as an arrow... At the very end where you plug in the PCIE it dips down a little due to the weight of the power cable. The weight / gravity of the connector is so minimal it's practically non existent but it's enough to get the end of the card to dip.
If I manually raise the wire level with the card, elevating that tiny bit of pressure the card becomes level at the end... As soon as I let the wire go it droops down to it's natural / relaxed position causing the end of the card to droop a few mm's.
After looking at the card there appears to be NO support at the far end... The front and especially the center where the heat sink's located there's plenty in place... Though at the far end that little bit of pressure is enough to pull the card down (ever so slightly.)
Honestly there's nothing I can do... Anywhere I position the power cable there's going to be a little bit of pressure (there's always some tension in the connectors) whether it be pulling down, up or side to side. And given the lack of support at the end of the GPU anyway I position the power cable, that little bit of weight / pressure is going to pull the end of the GPU / PCIE connectors with it.
Is this normal? Anything to be concerned about?
