Ok, so I am currently using an ASUS P5GDC-V Deluxe motherboard. It says it supports up to DDR-400 (in fact I've never actually seen a board claim to be able to support more than this)
My question is, can I use http://www.newegg.com/Product/Product.asp?Item=N82E16820227206
^Those ram modules to their full potential?
Currently I'm using a gig (2x512) of Crucial DDR-400, with loose timings (3-4-4-8). The problem with this set of memory is that I can only run 1:1 up to (240x16) even with bumping the VDimm. The CPU can handle 250x16, but only at 5:4
My question is, if I buy that above linked ram, will I be able to run 250x16 1:1?
Again, I'm confused because I've seen DDR-500, 600, and higher, yet I've never seen a board claim to support higher than 400.
Thanks in advance for the help. --Lutzy
edit: Also, should I use the above linked ones, or http://www.newegg.com/Product/Product.asp?Item=N82E16820146890
^These.
Thanks again.
^These.
Thanks again.
