Well...there won't be any test results with this case. You've heard of idiots, well I'm their king. Someone (me) didn't bother to run the phase system before I spent ALL the time installing everything in the case. I get it powered up and it starts its four minute countdown like it should. After the four minutes, the fans for the evaporator started up, but not the evaporator. The temp of the evaporator just stays at room temperature.
I've got an email off to Lil Devil, but I need to get in touch with Frozen CPU in the morning. I can order another one and get credit for this one after I return it. Now I have to tear apart the loop, take everything out, spend a fortune sending it back.....
I know nothing about these things, so I have no clue what to even check. I did check the fuse and it's fine.
Worst come to worst, I'm looking at the loop. Besides the rad and res, everything in on the motherboard. I may try and take everything out intact. It sure beats draining it and redoing it later. The only problem is FCU only has a BTX (reverse) case in white and I really don't want a white case.
