- Apr 5, 2012
- Malaysia, South East Asia.
Hey guys , plan to change my monitor next.
So my budge is around 400 - 500$ max , best to be around 400$ I don't mind investing 500$ on it , but depends on whether is it worth the investment and reasons given why should I invest on a 500$ monitor.
Problem is , even searching on the internet I have no idea what to look for while buying a good gaming monitor.
I know these at least
1)Response Rate , the lower the better , get something like 2ms or less
2)Refresh Rate , higher the better , for the monitor able to keep up the FPS produced by my GPU to reduce lag and ghosting and eye fatigue ( But I think for a 400$ monitor I can never find anything that's 140hz nor even for a 500$ )
3)IPS / TN , I heard IPS is bad for gaming for they have low response rate and TN are better even some more expensive TN panels looks better compared to IPS
4)Resolution , I will stick to 1080p @ 23" that's plenty for me.
5)Brightness , basically higher the brighter which is better right ?
So is there any other things I should look for when buying a good monitor for gaming ?
Is it possible to get a monitor that the pictures " looks good " and yet good for gaming , or basically a gaming monitor will definitely " look good "
Any if you guys could give me a few suggestion on the monitors I should check out that be nice so I can do a comparison myself too since I bet there are many models sold in US / Euro is not available here.
