- Jan 20, 2002
Does anyone have any idea what the safe/relative max draw of voltage is normal for a fan header on a mobo? Im looking to combine 4 fans into one 3-pin molex
to run onto the fan header and wanted an idea if this will work due to voltage limitations on the mobo. mobo in sig. Fans are Cougar turbine
http://www.newegg.com/Product/Product.aspx?Item=N82E16835553009
I have them on my 240 rad in a push/pull config.
any links or info is appreciated
