- Jun 19, 2008
- UK, Sheffield
Hi.
My existing spec:
Pentium 4 2.6c HT
Asus P4C800 Deluxe
2 x 1 Gig Corsair Value ram
4 x Seagate Barracuda (SATA with two on stripe RAID)
RME Fireface 800
Samsung Syncmaster 2232BW (22 inch widescreen)
As you can see my comp specs are proper old school.
I want to upgrade with a view to upgrading again in 2010, when the new architecture is established. I therefore don't want to spend £220 on a motherboard, but am looking to get best bang for buck with maybe the equipment listed below:
Intel E8400
Asus P5Q3 Deluxe
Corsair HX620
Corsair 2X1GB DDR3 1600MHZ 240PIN DIMM UNBUFFERED (mfr#: TW3X2G1600C9DHX )
ADS Tech PYRO1394 PCI Express
What do you think to the ram choice? I want to overclock it a bit.
I use Steinberg Nuendo a lot and want to start playin Call of Duty 4.
What GFX card would you get?
Mucho cheers,
Jim
My existing spec:
Pentium 4 2.6c HT
Asus P4C800 Deluxe
RME Fireface 800
Intel E8400
Asus P5Q3 Deluxe
Corsair HX620
Mucho cheers,
Jim
