- Aug 23, 2001
1 VOLT WONDER. Northy 2.4C @ 2.4GHz @ 1v. @ 3.2GHz 1.4v. Early prescott technology?
I acquired a Gigabyte motherboard today and it had vcores to 0.825v so I did a little testing like I usually do. Check them out.
The gigabyte GA-8IPE1000 is a better board for me. I owned two of the ABIT IS7's and both of them had very hot running southbridges. Essentially after a few days of using the IS7's my system became unstable and the mobo's are essentially burnt up. They will not run stable anymore without weird glitchies. Since a couple of the mosfets and southbridge got so hot they about burn you I am going to assume some to alot of the problem is there as also maybe small stresses with the memory.
My gigabyte southbridge is cool to the touch as alsoall the mosfets and the mobo lets me run my ram at 5:4 while my IS7 only allowed 3:2.
So I did some calculations OC'd and at default. This is what I found out.
Default
OC'd
So at intel specs they would be at 28w @ 2.4GHz @ 1.0v and 73w @ 3.2GHz. The higher wattage is calculated from AMPxVOLT which intel specs do not go by.
Suddenly the prescott prolems we have been hearing about seem to be simply BS. Prescott is supposed to run on 1.25v or less. Theoretically at the same speeds processors on different processes should run at lower watts/vcores. The tbredA was an exception
Default
OC'd
