- Aug 26, 2012
- Boston, USA
I'm designing and building a new PC for a friend and he has absolutely no idea what he's doing in the custom PC market. I haven't built a new system since early 2012 but recently water-cooled my own system and stared lovingly at the Titans.
Like the title says, the budget is $1,500. The caveat being that this includes every item that must go into the build from a new case to the very last bolt holding a new air-cooling tower in. I have next to no experience in the air-cooling towers. This will be a single GPU set up for daily computing, basic multimedia, and running two monitors for normal operation but a single 1080p screen while gaming. The monitors are not part of this budget but suggestions are welcome. If you see a problem or have a better idea, please say so but don't forget to say your reasoning. Comments of "that bit sucks, you suck." only hurt my feelings.
Case: Unknown
I dunno where to go with the case yet, as I wanted to pick out the motherboard at least before deciding on what size enclosure this will all be crammed into. I doubt I'd have any large form-factor GPUs in there but don't want something like the Bitfenix Prodigy. I personally build out of the CM Storm Stryker, but not many people want an obscenely large case.
CPU: Haswell i5 4670K
The CPU will not receive a major overclock, just something like 3.6-3.9Ghz will do it unless air is much better than my mind thinks.
Motherboard: Asus Z87-Pro LGA 1150
The Asus board above seems to be something reasonably priced without the silly Sabertooth gimmicks but still able to handle some mild overclocking and the Wi-Fi/dual-SLI requirements I have.
I don't need much in this department other than a single PCIe x16 lane and stable power throughout. Full 6Gb/s support would be nice as I'd like to look at a system SSD and data HDD with nice rates. Onboard wifi would be nice. ATX or smaller is sizing. I have no idea what is in this area anymore as the last time I looked I'd settled on an ASRock board for a theory 3770K build I'd done, but no frills and no gimmicks needed. Sabertooth need not apply.
PSU: Corsair HX650 80 Plus Gold
I have the most experience with Corsair units in the PSU space and have never had an issue with them even while overclocking, which is why I settled on this unit. I'm a bit fuzzy on whether or not I'll even need more than a 500W PSU for this system as it won't be particularly intense, so please just smack my hand if 650W is way overkill.
Memory: Crucial Ballistix Tactical 8Gb
Picked out this memory because it's a low-profile dual-channel kit of 1600 with relatively tight stock timings. I don't know much or have much experience OC'ing RAM or tightening the timings, so I picked something that will be stable and can be expanded to twice the space along with matching the motherboard.
Hard Drives: Samsung 840 120Gb and WD 1TB
I have the 256Gb Samsung SSD and absolutely love it, and that WD just seems to be a decent enough 2TB drive. The WD drive I am willing to consider other options but it needs to be between a 1TB and a 2TB.
GPU: EVGA 770 SC w/ACX
The EVGA 770 in this case is a bit more expensive than something like the Gigabyte 770 Knufire outlines on page 2 but I have a personal preference for EVGA in their customer service and quality of product.
Cooling Tower: Evo 212 or NH-D14
I have no experience whatsoever in the higher-ends of air cooling a CPU and will take any and all suggestions or links to read up on. I checked the cooling forum but it availed me of little. These two are simply the ones I've seen suggested most and appear quite reasonable on paper.
I realize now that I don't really have as much to go on here as I thought... If anyone's willing to fill in the blanks, that'd be great. I have no problem going and reading up on any of the topics, but I'm like a fish out of water in air-cooling and motherboard choices. The GPU I can do better with once I've got a price range, but that comes after I find out how much money is left in the piggy bank.
Case: Unknown
