I going to be putting my 2.4b back into my IT7 max2 v2 board.
Since this is a single channel board 845PE chipset, either if I buy a single stick or two stick I will get same performance give or take a couple to mb/s.
Should I buy a single 512mb stick or two 256mb sticks?
Im asking this since im not sure which of the 2 option will be most stable.
Usually one stick is the best option but im unsure that it being twice the size will affect stablilty.
Could 2 smaller 256 sticks be better.
Im going for something cheap with the ram and going to run 3.2v into it. Most likely either Kingmax 433ddr or Twinmos 400ddr CH-5 are the cheapest in my country.
