probably 10c below ambient at best. The baron cores when overvolted and overclocked really pump out alot of heat. A thoroughbred core would probably be best to use with a pelt because of the lowered heat output and lower voltage required to reach similar speeds.
So id probably be better off sticking w/ a 2000+ > a 2500+ baron if i want some low temps when it comes to o/c although i dont think ill be able to push my 2000+ that high. Right now its at 2088mhz and if i go any higher i start getting random restarts although i already do but thena gain i think it might be because of my psu.
if your 2000 craps out that low then your better off using a barton. Do you get higher on the barton thatn on the 2000. you mentioned power supply what brand and power rating?
your correct assuming a mobile barton will work. I'd reccomend replacing that psu as soon as possible though. There are known to be Kapowmax's. I had one catch on fire bout a year ago.
Yea the powmaxes are pretty goofy. This is the 2nd one iv had (not that i wanted to get a 2nd) but i plugged in the first one i had and after it ran for a good 20 seconds it made a flash inside and stopped working then smelled like some good burned crap. Im guessing it just burned up or something only reason i got another was becasue it was free.
