I have an asrock z68 extreme4 gen3 board and 16GB of Ripjaws I didn't need but bought because it was so cheap. Not knowing I would have a problem installing these four rams based on HS/fan combo I am unsure what to choose. I do not want to remove the tall HS because I believe it will void warranty.
I only want to achieve 4.5GHz so I don't think extreme cooling is necessary (ie Silver Arrow, NH-D14). But during the summer months my room can get into the 90+ temps with it getting 115 degrees outside so maybe these should still be options. I just do not know and would seek advice from the experts.
The ones I have read about are HR-02 Macho, Noctua NH-U12P-SE2, COOLER MASTER Hyper 212 Plus, Corsair H80, Prolimatech Genesis, Silver Arrow, and NH-D14. The last three probably being overkill but would like any comments you might have, especially with the high temps upstairs during summertime.
Again, clearance is very important (no modding). The system will be in my brothers old P182 case so I don't think any height issues. I would have put the Archon on the list if it had not been 170mm
Please help with my decision if you can. And suggestions other than the above are most welcome
