ah, i've had mine at 235......and ive seen higher, but they were water cooled at the least!!!
@Qatar.. If you are Brave enough, put your CPU voltage up to 1.9v, and see how well you can do...don't be frighened by the temp, the AXPs can still handle over 70C withour getting seriously damaged, so if you get temps in mid 50s to 60C, then that should be ok! and if you RAM and MB can handle that speed too....(I take no responcibillity for an damage that occurs because of my advise, im just going on wat mine was able to do, but mine was completly unlocked....)
