4GB Ballistix PC2-6400 (4 x 1GB), $37.98 AR if you received Buy.com $20 GCO Coupon
Summary: Buy two Crucial Ballistix PC2-6400 2GB kits at $53.99 each minus $20 Buy.com Google Checkout Coupon minus $50 Mail in rebate ($25 for each kit - limit 2).
$107.98 - $20 GCO Coupon - $50 MIR = $37.98 (free shipping as long as you select the right option).
First off, this assumes that you received a $20 coupon via email from Buy.com when using Google Checkout (mine was for $20 off $60 purchase). If you did not receive it, you still may be able to get the discount if you follow the link given below but YMMV. If you want to try the link below, you have to add everything to your cart, checkout using Google Checkout, and then login in to your Google account (discount will not show up until you login). I'll give step by step instructions below. If you are able to get the $20 discount without having received the email then please post your results.
1) Click on the following link and add two of them to your cart: Crucial Ballistix 2GB (2 x 1GB) PC2-6400
2) Close that browser after adding them to your cart and then click on the following link for the coupon: Click on this link
3) Even though you closed the previous browser, the new browser should still show that you have $107.98 in your cart so click on the view cart link (link is up in top right corner). Then click on Google Checkout button on top right side.
4) Login to your Google Checkout account and if the coupon is going to work the discount will be reflected. If you continue on with the purchase then MAKE SURE that you choose the Free Shipping option or else you will get charged.
5) Print out rebate form and and submit: Crucial Rebate Link (rebate terms say Limit 2 so you'll be fine buying 2 sets).
This is one of the hottest deals I've found on memory yet other than some of the HP memory deals that comes out from time to time (but it was only for PC2-5300).
Good Luck!!
Good Luck!!
