- Mar 11, 2001
- GR, MI
After many reboots this is the best I could come up with:
227x15 = 3405Mhz
Vcore = 1.45v
DDR2-800 RAM Divider
2.3v RAM Voltage
5-5-5-16 2T @ 850mhz (mem won't run any stable 4's despite Patriot's claim)
x5 HT Multiplier = 1133
Idle Temp = 23-24C
Load Temp = 37-39C (Thank You Danger Den!!)
PWM = 71C
Asus X1950Pro 256 @ 648/817 (now this I'm happy with)
SPECS:
Abit AN9-32X Fatal1ty
AMD X2 6000+ Revision JH-F3, Stepping 3.
4X1GB Patriot PC2-6400 "Low Latency" (4-4-4-12), 2.2v (not stable at default speeds unless on 5's)
Raptor 74GB 16mb Cache HDD
OCZ Powerstream 420ADJ
Asus EAX1950 Pro 256mb
Eheim 1250->Chevette Hcore w/ shrouded push/pull fan setup-> Danger Den TDX CPU block->Maze4 GPU block w/ 1/2" clear flex & radiator fluid!
My biggest complaint so far is the Uguru chip on this motherboard. On my old AI7 I could basically bypass the Uguru and on this board the overclocking features REQUIRE Uguru even in Windows! The software kept messing up and requiring a reinstall. Eventually I figured out how it all worked, and what options could be set and remembered through bios, and what settings could only be set w/ software. I would not buy this board again due to this setup. It makes my head hurt.
The second complaint comes from the memory which boasts low latency times, while not actually being able to run stable at default speeds w/ 2.3v on anything but 5's.
I tried different combinations of multipliers and dividers. The chip will not do much beyond 3.4ghz. I tried applying 1.65 volts and noted some increased stability but freeze-ups for the most part.
I'm going to run this for a while before I try pushing anything farther.
227x15 = 3405Mhz
Vcore = 1.45v
2.3v RAM Voltage
Idle Temp = 23-24C
PWM = 71C
SPECS:
