- Jan 4, 2013
Hey there! Ive decided to take my first water cooling experienced and couple that with a kraken g10 and a gtx 780 lightning. So far everything has been perfect for the past week. idle temps around 20 celcius and never over 45 when gaming. However this morning i was shocked when i pulled up after burner and saw my gpu was at almost 90 celcius idle. so i knew it was an issue with the water cooler(h100). Pump light works fine and i even tested 12v going to the pump.
So after doing more research i discovered it could possible be "air in the pump" Sure enough i powered on my computer, titled it and behold the water started to flow. SO, im assuming this has to do with the way I have this setup which is wrong because my rad is lower than my pump??? Would i be able to move the rad up 120mm to the next fan spot and not have issue??
Thank for all your help! Any will be helpful!
Anthony
Anthony
