I have updated my last results for my over clock of my amdfx 8350. My settings are 4.5 ghz 1.5v stable. Ran it for a hour and here are the results with my cosmos 2 compared to my hafx with 70c max temps.
If you have that set at 1.5v manually in the BIOS you're getting a whole lot of Vdroop. You may want to get the Vdroop under control and then redo the Oc settings. If you look at the Hwmonitor SS your Cpu V maxed at 1.476 and went as low as 1.404 V, somewhere in between them is your stable voltage. Get the Vdroop to where it stays as close to the set voltage as possible and then start over.
Ok I will do that I believe there are different modes for it. I had set it before but have not changed it back yet. Just wanted to test to see if the temp changed and it did.
