I was advised (here) that "you can easily go with the max supported 16Gb of a P55 based MOBO".
For i7-860 with no OC I understand I need 1066 DDR3 or faster, 1.5 voltage, dual channel memory. Searching newegg for 1066 or 1333 kits returns 2 x 2GB or 2 x 4GB results, where the 2 x 4GB kits are very expensive, two to four times as expensive per GB than the 2 x 2GB (say $25/GB vs $50/GB for 1066 memory, $25GB vs $100/GB for 1333 memory).
A P55 mobo (e.g. P7P55D) has four dual channel DDR3-1333/1066 memory slots.
Does the above mean that these are the correct configurations?
For 8GB: two of 2 x 2GB taking all four slots, for $200
For 12GB: one of 2x4 and one of 2x2 taking all four slots for $500
For 16GB: two of 2x4 taking all four slots for $800
What would you recommend?
