A couple of question about my OC
  • Thread starter Deleted member 117404
  • Start date
D
Guest
Got a question which of thes is better? there booth smooth stable but,
i got 2 versions
before OC3
setup 1
setup 2
1. 4079mhz 450 x 9 ram speed 450mhz 1:1
2. 3999mhz 500 x 8 ram speed 500mhz 1:1
why i did this? i purpuse make the change from multiplier 9 to 8 cause so i read the more fsb, the higher the ram can be. so i figuret out thats true so far, but which is technaliccy better?
sorry for the bad englisch i hope youll understand.
Can someone please tell me which is better to use and give me a good argument on it?
And the second question is, is divide 1:1 the best and fast?
latest question, i got dominator pc8500 1066mhz
is it so that i have to split 1066/2= max. supported FSB
i set it to 5-5-5-15, but can someone confirm a better/faster setup for that?
Thanks in advance!
The first would be 900MHz ram the second would be 1000MHz which is better? 4080 is 2% faster so. Its not that big of a difference. I don't think you would notice a difference but you may want to go with the 3999 so that your ram is at full speed.
what exactly do you mean with the number 3999?
duhh never mint :p hah is there any way to get this faster and 1:1 div is ok?
Either your math is off, or it's a typo. A FSB of 500MHz x 9 = 4.5GHz, while 500MHz x 8 = 4.0GHz. A 1:1 FSB : DRAM ratio at a FSB of 500MHz is DDR2-1000. If you meant a FSB of 450MHz at a 1:1 ratio (450 x 9 = 4.05GHz), then the effective DRAM frequency would be DDR2-900. You'd be better off w/ the higher 500MHz FSB at a 1:1 FSB : DRAM ratio = DDR2-1000, compared to the lower 450MHz FSB, even though you could utilize a 5:6 ratio for an effective DDR2-1080 w/ the same timings for a somewhat higher DRAM frequency.
indeed, it was a typo. I already thought that 500 * 8 is better. can you help me, how can i get the divider from 1:1 to 5:6 and if im correct goes my dram mhz higher?
well i got 500 x 8.5 working stable now at 4250 mhz and temp round about 40 ~ 45 degrees. you think i can go faster? vcore is 1.36 but when im trying to rase fsb im getting bsod, btw nb is on automatic, can you give me a good advise?
newest, stable 8.5 * 510 vcore 1.39375 but have to try dropping.
ram 5-5-5-12@ 2.1 volt
divider 1:1
ram 1020mhz
newest !
Is this a good clock pro clock, noob clock? this is not the first time but the way im doeing it, and how to chancge division to get more clock.../speed
thx
