- Oct 21, 2012
- Phoenix, Az
Alright, I'm working on a crappy Dell, and I have my next "real" pc mostly plotted out, and am looking forward to the build, though i probably won't pull the trigger on it till i have some free time to work on it (christmas probably)
So I am feeling the OC bug crawling through my skin, and I think I want to try something new/cheap.
SO... since I skipped the last 5 years of OC madness I find myself wanting to build a multicore OC test system on the cheap. This will mostly be a temp/cooling test bed so my requirements are...
VERY cheap CPU ~ multicore, which can OC insanely. It needs a high powerdraw and high temps. so inefficiency is key. As a result I figured something in an AMD flavor since i'm most comfortable OCing old Athlons. something in the $20-$50 range would be ideal
I'd like a MB with some life in it. So, something with good control, lots of options, solid temp monitoring, rugged construction... and xfire support, so that I might be able to use it on something like one of the new FX-8350... so i guess being a socket AM3+ probably will be required. (I don't mind spending up to 100 on the MB)
THANKS!
THANKS!
