!!!!!!!!!!!!!!!! SUCCES !!!!!!!!!!!!!!
I have everything running, and it seems that I'm in the clear. All of the planning and preparation paid off. Here are my observations that I can share:
++++++++++ slipstreaming SP2 int XP, integrating NVRaid drivers ++++++++
Yes, the Slipstreaming process ACTUALLY WORKS. Follow the instructions in the first post ONLY. Nothing else in that huge thread matters for your A8N32-SLI installation. Here it is again for your convenience:
Integration of NVRaid Drivers
nLite allows you to not only slipstream SP2 and integrate drivers, but to also allows you to install Hotfixes for Windows. I found a rather coprehensive list of them
here.
The bootable ISO image works too. Perhaps I was paranoid, but I made the CD volume name the same as that of my windows installation disk. Just put the your original Windows XP installation disk in your CD ROM, in Explorer right click on it, Properties, copy-paste.
I recommend that you select GUI Attended (you'll see this in nLite). I'm glad I selected this by instinct as this method allows you to select that you want to configure your internet connection later.
+++++++++ Active Armor, Nvidia Firewall..... ppfft ++++++++++++
I recommend that you just don't bother with the Nvidia Network interface. Just disable it in the Bios (it's the first one listed) and enable the Marvel one (second one listed). If you don't want to screw around with Active Armor, then it is important that you DISABLE the first port listed in the bios BEFORE INSTALLING WINDOWS. By virtue of the fact that you are disabling the nvidia port you are defacto disabling Active Armor. And, my friends, that is a good thing. My first attempt at installing Windows came to a crashing halt when I tried to install Zone Alarm. Even though I couldn't find where to disable Active Armor. Once I switched over to the Marvel one, Zone Alarm installed perfectly. However, to completely rid my new Raid volume from Active Armor disease, I had to start all over with Windows installation. I even quick-reformatted.
Note: The Marvel port is the one closest to the onboard Audio connectors.
By the way, the Marvel port is "marvelous". My DSL connection at 300KBS is not hindered one bit by using this port.
++++++++ SATA RAID 0 ++++++++++++++++
This went extremely easily. When you first boot up, Enable Sata1 and Sata2, then enable the Nvidia Raid Function. Save your bios settings, then when you see the prompt, press F10. Follow along. I have NO idea what "Optimal" settings for the stripe size means, so I didn't select it. I selected 64K as my stripe size as I had great success on my previous mobo's Raid settings.
++++++++++++ Windows Installation ++++++++++
When you start installing windows, DO NOT press F6 to load Raid drivers. If you have successfully created a CD with the integrated drivers (see previous section on slipstreaming), you will not need to, and doing so my cause BSOD's later (so I've read).
Here's the order I did things in:
Install windows using the slipstreamed CD
If you have a dual core processor:
Install the Windows Dual Core patch.... reboot
Install the AMD X2 patch..... reboot
If you didn't integrate all of the other drivers with the 6.86 chipset, then run the installation program and install them...... reboot. (I can't comment on whether this after-the-fact installation of these other drivers will work, however. I recommend you solve this problem ahead of time at the nLite stage of this game by integrating them along with the nvraid drivers)
Get your network connection up and running, sign into your internet provider.
Visit the Windows Update website and install any and all updates... reboot... repeat... wash... rinse... etc... until no more updates are available.
Install your antivirus software (I recommend Zone Alarm Antivirus).
Install your graphics driver. (YES, do this AFTER installing updates from Windows Update)... reboot.
Install Audio drivers....
Further software installation is up to you from here on.
I must admit that this installation went pretty painless because I had all of this stuff gathered up and prepared. Bottom line: I don't think you can easily install this mobo without having an old computer to research/download/prep with to begin with. I assume if you're reading this, you have access to an existing, functional computer. So, PLEASE do yourself a favor and using the nLite slipstreaming method.
THANKS EVERYONE FOR YOUR ASSISTANCE, and I hope my thread will help others.
