- May 17, 2005
- High Desert, Calif.
The machine is running XP Pro, and has the following disks & partitions:
Disk 0
partition 1= C
partition 2=E
Disk 1
partition 1=Z
no optic drives
Problem: every time upon reboot the system calls for a check of "E" because of file inconsistency. The only files on "E" are:
I don't really need "E" partition anymore, as I have added Disk 1 as storage, but I am uncertain of the consequences if I delete the boot.ini, NTDETECT.COM and the ntldr files. Indeed, Windows is preventing me from deleting the partition altogether. I changed the partition on Disk 1 from "E" to "Z" so I could change "E" to "D", which I thought might restore the natural order of things, but the system won't allow changing "E" at all. Rebooting doesn't solve anything either.
Any suggestions?
Disk 0
partition 1= C
partition 2=E
Disk 1
partition 1=Z
no optic drives
Code:
Directory of E:\
$RECYCLE.BIN
RECYCLER
System Volume Information
E:\
boot.ini 1 KB 3/22/2009 05:54:52 PM rhsa
NTDETECT.COM 46 KB 3/21/2009 09:29:46 PM rhsa
ntldr 244 KB 3/22/2009 05:51:22 PM rhsa
Total 3 folder(s); 3 file(s)
Total files size: 0 MB; 291 KB; 297822 Bytes
Any suggestions?
