kitanz
- Jul 28, 2014
Hey everyone, I was hoping you guys can tell me if im running a little hot. Also It seems I'm experiencing high temp fluctuations when stress testing the pc. At Idle its around 38-44. When stressing the system RealTemp said I hit 100C and that was only like 30 seconds into it! Also If you guys can let me know If my Cache&memory benchmark seems alright? Thank you!
Im Running an H100I for cooling.
PS. When stressing the system I saw the core speed drop down to 1k. Im guessing thats very unstable if it does that. Any suggestions?
Pictures Below
Idle
I had the fans in a push down setup and before I made this post I made them pull instead.
Stress Test #2 , [Cleaned as much as i could as far as dust, Replaced thermal compound from the one that comes with the H100I Series to Artic Silver 5, Changed fans to Pull setup.] Still Pretty high temps in my opinion for 4.4ghz! The most the core speed changed was from 4.4 to 4.399
Pictures Below
Idle
