- Jun 15, 2011
I'm posting this as I've not yet found a direct answer to my question. Hopefully, some of you can shed some light on this.
I'm looking to build a new computer to replace my old i7-2600k workhorse. I am centering around the AMD 3900X CPU, but I am put off by the chipset fans on the X570 boards. I'm going for a watercooled system, and a small, noisy, prone-to-fail, chipset fan is not something I can live with. I'm willing to pay more to avoid the chipset fan, but the prices of the Asrock x570 Aqua and the Gigabyte X570 Ultimate are outragous. So it seems that my next best option would be a high-end X470 (or B450?)
I've looked at the VRM-chart posted on Reddit to get my bearings, as I figure I should choose the top-tier VRMs for this CPU. The Gigabyte X470 Aorus Gaming 7 was my first choice, but my retailer can't guarantee that the BIOS is up to date to support Ryzen 3xxx. And buying a second CPU just to update the BIOS increases the price further. I'd have the same BIOS problem with the Asrock X470 Taichi.
MSI has a flashback option, and I've looked at the MSI X470 Gaming M7 AC, which according to a test at Techpowerup performs just as well as the Asrock X570 Taichi for overclocking the 3900X. The ASUS Crosshair VII Hero will allow for BIOS flashback, but it's the most expensive of all the X470 options.
Now, to shave off the price, I could get the MSI Gaming Pro Carbon. But looking only at the above VRM tier list, this choice is a step down. Also, I don't need SLI, so a B450 board would be sufficient as long as it can deliver stable power to an overclocked 3900X (but can it?).
In short, which of the following options would be best suited to run an overclocked AMD 3900X?
1) Buy a Gigabyte X470 Aorus Gaming 7 + old AMD CPU to flash BIOS.
2) Buy MSI X470 Gaming M7 AC
3) Buy MSI X470 Gaming Pro Carbon to save some money
4) Buy the more expensive ASUS Crosshair VII Hero
5) Save even more money buying a B450 board (in that case, which?)
Does anybody have an opinion of which of these options are most viable? all comments appreciated!
