- Jul 20, 2002
I've read a little bit about the AMD Accelerated Processing Units and, according to wikipedia the steamroller architecture will feature:
Kaveri A-series APU
Desktop budget and mainstream markets (FM2+): The Trinity / Richland APU line is scheduled to be replaced on 14 January 2014 by the Kaveri APU line, as the third generation of A10, A8, A6 and A4 series for the desktop market. Currently known new model is a quad-core A10-7850K APU, with a 3.7 GHz core frequency and 4 MB L2 cache, incorporating a 720 MHz GPU with 512 stream processors and 856 GFLOPS of total processing power.[9]
The new APUs will have two to four enhanced Steamroller B cores, and a GCN 1.1 Volcanic Islands GPU.[10] Reports have also claimed that the new APU will contain both DDR3 and GDDR5 integrated memory controllers, although it appears that using both memory types at the same time will not be possible.[11] Kaveri APUs will utilize the new FM2+ socket, and they will not be backwards compatible with the previous generation of FM2 motherboards.[12]
What do these APU's do for gaming though? Can they work in conjuction w/a discrete video card?
Kaveri A-series APU
