Sapphire AMD E350 Pure Fusion ITX
4Gb 1333 Sodimm DDR3
AverMedia Dual DVT-B PCIe TV
500gb WD Blue
Pico 120w
3TB External
Intended to be a mini home server, this Fusion ITX rig hits 65-70c merely transferring a file. And stays there! Theres a 40mm intake fan underneath (SATA ports) which seems useless and even with the lid off, idles at 55c+ (Core,Real Temp)
I've removed the sinks, cleaned up and applied mx-4 to them with no results.
The led 40mm (3000-4000rpm) blows a fairly good breeze. No I/O plate. Tried a slim 80mm spread over them both which was just noisey. Room for a front 40mm intake right against the LED display, I suppose ? Pulling just 30w, the idea was to leave it on most of the time of course. Not possible yet. I could customize a heatsink to cover the 2 processors and add a slim 80mm or so. The problem is, in this acrylic case I only have 1 and a half inches from processors to the lid. I'd like to avoid dremelling the lid. Any suggestions ?
500gb WD Blue
Pico 120w
3TB External
