Well, i've debated it as well as I could and I just can't decide so im asking you, the people of overclockers forums , to help me out!
I heard AMD is better for gaming and INTEL is better for most of everything else but I just can't decide if it's worth it or not. If I go with AMD The best Processor I can get is the AMD Athlon 64 3500+ 64-BIT 2.2GHz, 512kb Cache 90nm processor. I heard this processor is Killer for overclocking and awesome for anything from gaming to anything else and extremely fast, sometimes, even out-performing the Pentium 4 3.0GHz!
If I go with Intel I can probably get Intel Pentium 4 3.4GHz, 800MHz FSB, 1MB L2 Cache w/HT or maybe even 3.6 or 3.8! Another advantage to me going with Intel is I can get the computer for cheaper all together and get dual hard drives of 320gb or 400gb, maybe even 500gb total in raid and 2GB ram instead of 1GB.
So How about it? Im planning to overclock either processor I get anyway, which one do you think I should go for? Advantages? Disadvantages? Will I notice a huge performance hit if I go with Intel?
I know it probably depends on the rest of your contents so here's the basics of what the system will have if it's intel:
Intel Pentium 4 3.4GHz Processor, 800MHz FSB, 1MB L2 Cache w/HT
2GB PC-3200 DDR Ram @ 400MHz
2x 200GB 7200RPM 8MB Cache HDD's in RAID
Motherboard Undecided
Nvidia GeForce 6800GT 256mb w/TV/DVI
Soundblaster Audigy ZS 2
NEC 1.44MB Black Internal Floppy Drive
Encore 56K V.92 Internal PCI Fax Modem
Some kind of sufficient cooling & power supply and a nice case.
16x DVD+/-RW Dual Layer
If I go with AMD then:
MSI K8N Neo4 Platinum Motherboard
AMD Athlon 64 3500+ Winchester Socket 939 64-BIT
Creative Labs Sound Blaster Audigy 2 ZS
MSI NVIDIA GeForce 6800 GT Video Card
Hitachi 250GB 7200RPM Sata Hard Drive
Thermaltake Venus 12 CPU Cooler
1GB PC-3200 DDR Ram @ 400MHz
NEC 16x Double Layer DVD+/-RW Drive Black
Rosewill 450 Watt Dual Fan Power Supply
So what do you guys think? AMD or INTEL
