- Sep 13, 2011
Here are my results using maxmem at various speeds. Note that all these results were from fresh boots on windows 7 x64.
The ram i am using is 2x 2GB ADATA DDR3 1600 MHz 9-9-9-24 1.65V
and 2x 4GB ADATA DDR3 1600 MHZ 9-9-9-24 1.65V. yes they are mixed and matched with no problems. CPU is an i7 3770k @ 4.5 ghz
For the results in this log, all the ram was undervolted to 1.55V.
The log is pretty interesting in how command rate and timings affect the speed, and vice versa. The faster the ram speed is, the more 1T command rate makes a difference over 2T
Code:
1600 MHZ 9-9-9-24-1T
COPY READ WRITE SCORE LATENCY
22592 MBPS 19836 MBPS 21184 MBPS 12.95 GBPS 61.5 ns
22702 MBPS 20335 MBPS 21055 MBPS 12.95 GBPS 61.9 ns
22592 MBPS 20551 MBPS 21159 MBPS 12.95 GBPS 61.7 ns
22592 MBPS 20491 MBPS 20807 MBPS 12.95 GBPS 61.4 ns
AVERAGE 22620 MBPS 20303 MBPS 21051 MBPS 12.95 GBPS 61.6 ns
1600 MHZ 9-9-9-24-2T
20255 MBPS 12057 MBPS 13379 MBPS 12.72 GBPS 62.7 ns
22702 MBPS 20390 MBPS 20978 MBPS 20.26 GBPS 62.5 ns
22702 MBPS 19853 MBPS 21108 MBPS 20.06 GBPS 62.6 ns
22592 MBPS 20280 MBPS 21160 MBPS 20.26 GBPS 62.9 ns
AVERAGE 22063 MBPS 18145 MBPS 19156 MBPS 18.32 GBPS 62.7 ns
1600 MHZ 9-9-8-22-1T
22702 MBPS 20519 MBPS 21058 MBPS 20.79 GBPS 61.7 ns
22485 MBPS 20415 MBPS 20926 MBPS 20.67 GBPS 61.7 ns
22592 MBPS 20415 MBPS 20928 MBPS 20.67 GBPS 61.6 ns
22485 MBPS 20447 MBPS 20916 MBPS 20.68 GBPS 62.0 ns
AVERAGE 22567 MBPS 20449 MBPS 20957 MBPS 20.70 GBPS 61.8 ns
1600 MHZ 9-9-8-20-1T
22485 MBPS 20321 MBPS 21083 MBPS 20.70 GBPS 62.0 ns
22485 MBPS 20489 MBPS 20934 MBPS 20.71 GBPS 62.0 ns
22592 MBPS 20461 MBPS 20908 MBPS 20.68 GBPS 62.0 ns
22592 MBPS 20364 MBPS 21110 MBPS 20.74 GBPS 61.9 ns
AVERAGE 22539 MBPS 20409 MBPS 21009 MBPS 20.71 GBPS 62.0 ns
1800 MHZ 10-11-10-30-2T
24348 MBPS 21215 MBPS 21419 MBPS 21.32 GBPS 61.9 ns
24348 MBPS 21433 MBPS 21347 MBPS 21.39 GBPS 61.8 ns
24100 MBPS 21569 MBPS 21440 MBPS 21.50 GBPS 61.9 ns
24348 MBPS 21504 MBPS 21389 MBPS 21.45 GBPS 61.8 ns
AVERAGE 24286 MBPS 21430 MBPS 21398 MBPS 21.42 GBPS 61.9 ns
1800 MHZ 10-11-10-30-1T
24223 MBPS 21999 MBPS 21504 MBPS 21.75 GBPS 60.8 ns
24223 MBPS 21910 MBPS 21442 MBPS 21.68 GBPS 60.9 ns
24476 MBPS 22003 MBPS 21361 MBPS 21.68 GBPS 60.6 ns
24348 MBPS 21987 MBPS 21346 MBPS 21.67 GBPS 60.7 ns
AVERAGE 24318 MBPS 21975 MBPS 21413 MBPS 21.7 GBPS 60.8
1866 MHZ 10-11-10-30-2T
SYSTEM SHUTS OFF WHEN STARTING BENCHMARK
