PSU is new, about a year old but was never used till this build, it was bought for a backup PSU for our Compaq, with 1.3 Duron and my first build, Shuttle AK12, with 1.3 Duron, The old 230W PSU that I used for the AK12 build has pots, and the spec. on it is as good or better than most 250s. I had the 420W PSU so I used it. When I stop Prime from running I will check for pots in the PSU and will post back with findings.
Prime has been running now for 16hrs,plus.
Settings are 2.6V on memory, actual unknown.
V Core set to 1.8, MBM shows 1.74, memory set to 100%, timings 11-3-3-2.5, mem freq. 200Mhz/400DDR, CPU speed shows 2205Mhz. CPU temp is holding at 47to48C.
I am pleased.
Thanks for the reply --mecoleg-- but I don't understand what you are saying, maybe you could explain in more detail. I am a nubee at overclocking. I do know that my CPU is one of the newer ones that is hard locked or multi locked at 11X, and the last time I checked about 6 months ago there was no chip mod that would unlock this CPU. I bought used because of price and in the hope that I would get an earlier processor. No Bios setting can change this as far as I know from reading in Forums. I also tried. From what I have learned is that CPU speed is a multiple of memory speed X CPU setting which in my case is locked at 11X, then 11X200Mhz=2200Mhz CPU speed. I am happy with the present results but always ready to learn dufferent ways of doing things.
Prime has now ran 17 hrs. Happy--Happy--this old lap top that I am using drives me crazy, hate touch pads, allways draging my thumb across it. It was a gift and it works so I guess I shouldn't knock it. Guess if I could type better that wouldn't happen.
Later guys,
PopRichie
