- Dec 15, 2010
- La-la-latvia AKA Middle of Nowhere
Hi there!
Seeking some advice. I'll try to keep the long story... slightly less longer.
Here goes.
When I bought my 555 one of the first things I tried to do was to unlock it, obviously. This forum helped me a lot, but in the end I just gave up and did not manage to get it stable. It pretty much boiled down to the following symptoms. I would POST, boot into Windows and then Windows Explorer and Catalyst would crash, but otherwise everything would run OK(-ish). I would pass 48hrs of Prime95 in blend without errors, hell, I could even OC the unlocked CPU to 3.9 and run Prime95 perfectly fine, while making some rhymes... anyhow, after numerous multi, voltage, NB settings, I just gave up, as two cores where just fine with me, considering the OC I got out of them.
Now, today I randomly started thinking over the symptoms and what I tried to do back then and I got some questions.
Would it be possible that the actual culprit is not the CPU, but something to do with memory? Obviously, I first tried to OC/unlock the CPU before fiddling with RAM, so everything with done @ stock speed and timings.
At the moment, I'm sitting with unlocked cores, Prime95 is running fine, as it did... however, just like the last time, explorer crashed on boot, then Catalyst crashed, this time I can't start Firefox, but Chrome runs without a problem.
I'd really like to hear some input/advice on the issues. Some wild ideas that I might try
Many thanks and sorry for my English Almost silly o'clock and a beer or two too many
Here goes.
