- Jan 14, 2003
- Stuttgart, Germany
One more good deal if you're in the market for the best 24" monitor made today - and I can verify as I have one.
Dell currently has the 2408WFP on sale for $499, but use this coupon - 2J0TX0Z5NW22MB and you'll get another 10% off, making the total $449 - a very good deal on this monitor. There are some other monitors this coupon can be used on as well, but the 2408WFP is typically about $675, so this is certainly the one with the most $$ off list.
If you want cheaper, and don't mind a TN panel, the S2409W is available for $224 after coupon.
http://accessories.us.dell.com/sna/...etail.aspx?c=us&l=en&s=bsd&cs=04&sku=320-6272
Yes, it's pricier than the $249 Acer versions out there, but this monitor is in an entirely different league than any TN based 24" out there. With a little tweaking of the settings, this sucker is gorgeous.
It also has four built-in USB ports, and a 9-in-2 media card reader.
Height, tilt, and swivel adjustments too.
Connectivity:
High Definition Multimedia Interface (HDMI)
Digital Visual Interface - Digital (DVI-D) with High Definition Content Protection (HDCP)
DisplayPort
Video Graphics Array (VGA)
Component Video
Separate Video (S-Video)
Composite Video
Tech specs:
Panel Size: 24" / 24"
Panel Type: VA - Vertical alignment (S-PVA)
Maximum Resolution: 1920 x 1200
Contrast Ratio: 1300:1 (typical)
Brightness: 400cd/m2 (typical)
Response Time: 6 ms (gray to gray) typical
Viewing Angle: 178° / 178° (typical)
Color Support: 16.7 million colors; 110% color gamut
Pixel Pitch: 0.270 mm
Connectivity:
DisplayPort
Component Video
Composite Video
Tech specs:
