i have put together what i think is ok for a single cpu and vga loop but would like some feed back from people that no a lot more than me
questions
1) will this be ok and do the job
2) have i got everything i need apart from two fans for rad
i am unsure on tubing and fitting size
thanks in advance
XSPC Dual 5.25" Bay Reservoir - Clear
Product Code: BR525DC Manufacturers Code: BR525DC 1
remove £31.48 £31.48
12V Laing DDC-1T+ Ultra 18W (MCP355)w/XSPC V3 Acetal Pump Top
Product Code: XSPC18W-ACE Manufacturers Code: XSPC18W-ACE 1
remove £61.10 £61.10
Black Ice GT Stealth 240 Radiator
Product Code: GTS240 Manufacturers Code: GTS240 1
remove £32.84 £32.84
EK-Supreme HighFlow CPU Block - Plexi 775/1156/1366/AM3
Product Code: 10334 Manufacturers Code: 10334 25
remove £43.99 £43.99
EK-FC5870 V2 - Plexi (Non Reference ATI 5870)
Product Code: 12346 Manufacturers Code: 12346 3
remove £59.56 £59.56
PVC 10/8 Blue/UV Blue Hose 1m
Product Code: 57007 Manufacturers Code: 57007 18
remove £1.69 £10.14
1/4" BSPP - 10/8mm Compression - Silver Nickel
Product Code: 62254 Manufacturers Code: 62254 1000
remove £1.27 £12.70
PrimoChill PURE Performance Coolant (32 oz.) - Steel Blue
Product Code: 30072 Manufacturers Code: 30072 50
remove £6.80 £6.80
questions
thanks in advance
remove £1.69 £10.14
remove £1.27 £12.70
remove £6.80 £6.80
