- Jul 8, 2004
- Tallahassee FL
I did see a thing about a guy that ran a submerged comp, but he didn't have anything crculating the fluid. It was not FluidXP, I think it was some 3M product. He didnt have very good temps though. He still had a HS on the proc. He tried to run it bare die, but it got too hot with no circulation. I use(d) fluid XP, but stopped. I got a bottle for 25 bucks. It does lubricate, prevent corrosion, etc, but it also had some sort of bad reaction with something in my loop. I have a dtek procore, a WW, an MCP600, and a blue clear bayres, connected with 1/2" clearflex 60. One of it's properties is that it coats all the surfaces in the loop with a layer of some type of polymer. What this means in reality is that everything is coated with a white film, tubing, block, res, and (I assume) the inside of the pump and rad. I drained the system because little pieces of this coating were flaking off and getting caught in the whitewater. I was still getting good temps with it, despite a slopily applied layer of AS5. It would keep my A64 3500+ @10x250 1.55V around 40 degrees under load, with about a 76-78 degree ambient. I'm going to be re-doing my system with plain distilled water in a few weeks so I can compare temps. BTW, procore heater cores don't have any aluminum, correct? so I would not need an anti-corrosive, just distilled water? I think that it is too heavy to be aluminum, but I'm not sure. Also, fluidXP smells really bad. It stunk when I drained it. But, it doesnt conduct, so...
